The customer is upgrading to CISPro 2023 SP1 having setup a new CISPro application server. For this version of CISPro ODAC is optional and is only required if PDF document generation is required. However each schema update step requires a supported version of ODAC for that version, so for example if upgrading from CISPro 2020 SP1 to CISPro 2023 SP1, ODAC 12.2 or the configured ODAC 19c is required. If a valid ODAC is missing then the following error is shown in the schema updater:
Update failed: An internal error occurred: Unable to assign database resources for AccessId 'xxx': Error connecting to Oracle database on server <EZ Connect String or TNS Alias>: Could not load file or assembly 'Oracle.DataAccess, Version=4.112.3.0 …
