Services or customers occasionally use the CISPro API to dispense from Containers, using for example /inventory/api/v1/containers/{id}/DispenseForUse. The endpoint accepts a ContextUrn value, but this is then not seen in CISPro. Why is the ContextUrn property hidden by default?
The ContextUrn field is only useful for Hub and Capture users and the majority of CISPro customers do not use Hub and Capture to dispense CISPro Containers. Therefore the ContextUrn field is hidden by default but it can be easily unhidden by CISPro Support or Services.
Note that there is a ContextUrn property on both Container Dispense Transaction and Receipt Lot. The former is used in the dispensing case above whilst the Receipt Lot ContextUrn would also be used from Hub or Capture but from Batch Registration (Container receipt).
