What is the difference between the Ensemble Pharmacophore Generation protocol and Common Feature Pharmacophore Generation protocol in DS2020? It seems that the function of the two protocols is similar? Using the same hiphop , and generate ROC plot?
They are similar, although i would prefer the term complementary. Indeed, both use Catalyst Hiphop, which, like all classical pharmacophore elucidation algorithms, works on the assumption that all the actives in the training set share a common target, binding site and interaction mode. Since their conception, training sets have become much bigger and more diverse, so that these conditions can no longer taken for granted.
The Common Feature Pharmacophore Generation protocol mirrors essentially the original Catalyst workflow for Hiphop; it can accept up to 32 active "lead" compounds and will generate a number of pharmacophore hypotheses for the training set with detailed information on their respective figures of merit to support an informed selection. If you provide an independent test set, it will also use it to a generate ROC curve for each hypothesis.
Ensemble Pharmacophore Generation, new in BIOVIA Discovery Studio 2020, automates the process that one would previously have applied manually, if the available data were too many or the compounds were too diverse: it clusters the active ligands using pharmacophore fingerprints, then runs Hiphop on a subset from every cluster that has more than 10 members and retains the best hypothesis for each cluster, if it fulfils the quality criteria. For each pharmacophore it will generate a ROC plot using all actives of the given cluster and all inactives of the entire data set. This is also used to optimise the FitValue cut-offs for each hypothesis to give the best discrimination between actives and inactives.
Personally, I would probably still prefer CFPG at the moment for small, homogeneous sets, if I can be reasonably certain that a single pharmacophore can explain the bioactivity, i.e. that all the actives bind to the same active site. And I would turn to EPG for large and/or diverse compound sets, or if there is a risk of multiple modes of action, like e.g. for data from phenotypical screens.
More details on the workings of the two protocols can be found in the Pharmacophores section of the help pages.
You may also find the recent Release E-Seminar "What's New in BIOVIA Discovery Studio 2020" interesting, where the new Ensemble Pharmacophore Generation protocol has been featured (the relevant section starts after about 12½ minutes). It is available for replay here.
