Visualization on a laptop
My school has bought discovery studio for numerous research groups in my school.
I'm currently doing some research regarding to some enzymes, and have a suspected inhibitor.
So my teacher said that i can try to use DS to visualize the interaction between the enzyme and the suspected inhibitor(from the overview).
I think the school runs DS in one of our computing clusters, and the research groups are getting the client software.
My problem is that i'm going to buy a new laptop, however, probably not be able to buy the ones with NVIDIA QuadroFX graphic card.
Is a NVIDIA 8400M-GS be able to do the visualization, or it'll be really slow or completely crashed??
thanks a lot.
Answers 1
HP
HP 2008-03-21
Hi Davince,
There is a big difference between a Quadro and a 8400m. But you are at least ahead of the game if you have a dedicated NVIDIA or ATI graphics chip in your laptop. If the main reason (greater the 60%) for purchasing this laptop is to do Visualization, using Discovery Studio or other graphics applications, you would be better off getting a higher end chip. That being said, I've been able to run moderately complex visualization on fairly low end chips.
If you are shoping for more of a general purpose laptop for all your school work and only want to do some moderate ( a subjective term for sure ) visualization this chip "might" be ok.
Typically Accelrys can only test a subset of the current graphics chip sets. This is because of the large number of different possible combinations. So Accelrys can only "officially" recommend those chips they have tested.
Let me offer a suggestion. Try and find a friend or PC shop that has a laptop with a similar configuration that will let in install the Free DS Visualizer and give it a go. You might want to bring along some sample molecules to play with. Also, while your on one of the expensive school machines play around with different graphics settings and really get familiar with how the graphics perform under many different settings. Turning on all the bells and whistles and cranking DS up the the highest quality can really tax even a high end system. But the goal is to get familar with how the many different graphics setting affect performance. This way when you are on more a mere mortal machine you can effectively judge the system and determine if it would meet your needs or not.
You can get additional performance as well with faster memory and CPU settings in your machine. My "old" laptop has about a three year old consumer chip and it does pretty good.
Also, if your running Windows Vista, you might want to see how performance is affected by turning off Aero glass.
And when you do get a system, report back and let us know what you think!
Best of luck!
Cheers,
Greg
