Reading Frames
Hello Everyone:
Could some one help with this..I am using DS Visualizer 1.5. Sometimes when I am doing an RMSD by opening one structure, and inserting the second (as described in the help section), the structures load from different reading frames, thus I can not do the RMSD. Could someone tell me how to load structures in from the same read reading frame. Everything works fine if both structures are in the same format (e.g. pdb or mol2), but when each structure loaded is of a different format, I get the reading frame problems.
Thanks.
Mark
Answers 1
HP
HP 2006-06-07
Please try using the insert into or drag-drop functionality in DS Vis 1.6 (July 2006 release) when available. This may have been a bug in DS Vis. 1.5. Open a new structure window (File menu) and drag and drop 2 or more structure files (e.g. PDB) into the window; highlight (select) one of the structures; and then perform RMSD calculation.
