that's protocol has parameter 'plane scale', it appears plan parallel. what's included of plan parallel? or it has charge, like potential plane?
Am I correct to assume that you are using the custom protocols posted in the discussions:
https://community.accelrys.com/message/1379#1379 ?
These protocols were precursors to the Implicit Membrane protocols and functionality that were added to the product in DS 2.5 and later.
The planes themselves are just a visual aid but what happens during a simulation when these planes are present is that the region of the protein which falls in between the two planes is treated as having a low-dielectric to approximate the non-polar part of the lipid bilayer. In this version of the protocols, it uses the GBSW model in CHARMm to calculate the polar contribution to solvation energy in Generalized Born approximation with an implicit membrane. In addition, the non-polar contribution to solvation energy are approximated with a solvent-accessible surface area dependent (SA) term, which is calculated with a uniform surface tension coefficient with the same value applied to all atoms. A detailed description of the approaches can be found in
Spassov, V.Z.; Yan, L.; Szalma, S. Introducing an implicit membrane in Generalized Born/Solvent Accessibility Continuum solvent models. J. Phys. Chem. B , 2002 106, 8726-8738.
and Im W.; Lee M.;, Brooks C.; Generalized born model with a simple smoothing function. Journal of Computational Chemistry. 2003, 24, 14, 1691-1702.
Discovery Studio version 2.1 and higher can calculate energies using
implicit membrane bilayer if a "thickness" parameter is defined.
can i use that's protocols (if a "thickness" parameter ) for membrane
monolayer?
monolayer?
These methods are not specific enough to distinguish between a monolayer and bilayer. They are intended to implicitly represent a membrane (there are no actual lipid molecules present). If you wanted to you could just use the thickness of a monolayer.
