periodic boundary condition
I have done a simulation for the lipid complex. Once the simulation is done its shows WARNING "No periodic boundary conditions defined. Turning constant pressure off. Production Type changed from NPT to NVT. " Although I can set explicit periodic conditions through solvation but I don't want to do solvation. so just want to ask if any other method to set periodic boundary conditions without doing solvation.
Answers 3
JS
JS 2020-11-09
Hi Archi, as far as I know the only way to create a system that will subsequently use Periodic Boundary Conditions in Discovery Studio is to either use the 'Solvation' protocol or the 'Solvate with Explicit Membrane'. You mention that your system is a lipid complex, did you use 'Solvate with Explicit Membrane' to generate that system? If not, how did you generate your system? Which version of Discovery Studio are you using? Maybe you can attach your input files.
AG
AG 2020-11-10
Earlier I have used 'Solvate with Explicit Membrane' to generate my system, but it adds to much water molecules that doesn't need and adding only to computational cost. So i used NAMD to generate the system and then used DS. One question Is there any way to limit water molecules in solvation step. i'm using DS 2019 client on windows 10 workstation.
CB
CB 2020-11-10
Hi Archi. The Minimum Z Distance from Boundary parameter in the Solvate with Explicit Membrane protocol mainly affects how many waters are added. This parameter can be changed but the defaults have been set with the nonbond cutoffs in mind, to avoid the situation where atoms could be close enough to interact with their periodic images.
