is there such property in D.S 2.5 protocols? and i am talking about non-pharmacophoric multiconformational search .. i.e. I need a correlation between 3D-multiconf. descriptors and continues dependent variable (IC50) rather than active/inactive boolian.
another questions is: is there a formal representation of racemic compounds in a qsar calculation? and if yes, how do i account for a racemic center in that sense?
also, could i paste a whole spreadsheet-column into a .sd file?
Thanks in advance.
(1) There is a Create 3D QSAR protocol that matches your description very well. It uses spatial grid energies as descriptors to build a partial least squares model, which deals with continuous dependent variables. There is a prerequisite that your molecular data set should be well aligned before you can use this protocol.
(2) I am not aware of any good way to use chirality as a descriptor in a QSAR equation, and I suspect it won't be a good descriptor because the effect of being a chiral molecule is mostly manifested in other factors such as steric interactions, etc.
(3) It is quite easy to paste a column in an sd file: Create a new attribute by right-click anywhere in the data table and choose "Add Attributes" (type in Name, default value and type). Select the newly created attribute column and then paste your data from the clipboard.
Thank you so much Dr.Zhang, but youhave probably forgotten to tell me where could I find that protocol
(2) about chirality .. I am rather having some racemic compounds in the training set with one chiral center, so, that having a great influence on the expected MIF (the most active configuration being unknown), i was of inputting the two mirror images with the same activity value as a slight make up for the error (as if they were equiactive). But I am really not sure if that would make things more erroneous! any ideas?
You need to upgrade to DS3.0 to use the 3D QSAR protocol. I think it has been added to the QSAR protocols since DS2.5.5.
If the activity is measured using racemic mixtures, then you really don't know which form is active (or both). In this case it doesn't matter which form you use in your QSAR modeling. You can try other QSAR methods, such as GFA, PLS, etc.
Since you have no informaiton about which chiral form (or both) is responsible for the activity, the best way you can do is to include both forms in your taining set. Or you can try each form, and then pick up the one gives better correlation.
hmmm, could i instead try to calculate the existance ratio of one optical isomer as dG = RTlnZ, where Z is the ratio of the concentrations of the two isomers?! and this way i could choose the statistically more significant (as in my case the chirality is mainly at saturated rings attachment points, i.e. certainly the equatorial configuration for the bulky substituent is more favourable)?
Also could someone please upload me the "Create 3D QSAR" protocol xml file .. as i couldn't find it in my D.S 2.5.5 collection
