Met error when using Loop Refinement protocol
Hi all,
I met an error when using Loop Refinement protocol to refine a loop (I use DS2.1 Win version).This is the error information, as below.Can anyone tell me why I get this error? Thanks in advance!!!
Can't use an undefined value as an ARRAY reference at D:\\Program Files\\SciTegic\\apps\\accelrys\\ds/lang/perl/ProteinModeling/Looper_run.pm line 626.
ProteinModeling::Looper_run::create_amino_incl_file('ProteinModeling::Looper_run=HASH(0xb1a4828)') called at D:\\Program Files\\SciTegic\\apps\\accelrys\\ds/lang/perl/ProteinModeling/Looper_run.pm line 455
ProteinModeling::Looper_run::create_charm_input_files('ProteinModeling::Looper_run=HASH(0xb1a4828)') called at D:\\Program Files\\SciTegic\\apps\\accelrys\\ds/lang/perl/ProteinModeling/Looper_run.pm line 371
ProteinModeling::Looper_run::looper_setup('ProteinModeling::Looper_run=HASH(0xb1a4828)') called at D:\\Program Files\\SciTegic\\apps\\accelrys\\ds/lang/perl/Components/Looper.pm line 198
main:Red FacenProcess
Error calling function
Error during call to function pilot::setup::scriptingOnProcess
PerlScript::HandleError: Pipeline Pilot exception caught
PerlScript::Call: Pipeline Pilot exception caught
CComponentPerlPlugin:Red FacenProcess: Pipeline Pilot exception caught
-> Perl (on Server) - error during Data Record Processing phase
CProtocolStd:Red FacenProcess: Pipeline Pilot exception caught
CProtocol:Red FacenProcess: Pipeline Pilot exception caught
-> Subprotocol - error during Data Record Processing phase
CProtocolRtc:Red FacenProcess: Pipeline Pilot exception caught
-> Looper - error during Data Record Processing phase
vcRunComponent:Red FacenProcess: Pipeline Pilot exception caught
vcRunComponent:RazzerrocessData: Pipeline Pilot exception caught
CShortcutComponent:Red FacenProcess: Pipeline Pilot exception caught
-> Shortcut Component - error during Data Record Processing phase
Protocol Run DS Protocol, user Knight: Pipeline Pilot exception caught
Protocol Run DS Protocol, user Knight: Protocol failed: Pipeline Pilot error
Pipeline Pilot Server version 6.1.6.0
Server OS: Windows 6.0 Workstation Service Pack 1
Answers 3
HP
HP 2009-07-13
It is not clear what the problem is from the error messages. Could you please open a support call so that our support scientist can work with you to diagnose the problem directly?
HP
HP 2009-07-13
Jurgen Koska and I analyzed additionally the problem. Most probably the failure is because of one or more missing template files with the extension “tmp� in the ../ds/data/CHARMm/Looper directory. For example, if the protein is typed by CHARMm FF, a file “aminoh_CHARMm.tmp� should be present in …/ds/data/CHARMm/Looper folder.
I would ask the customer to check for the existence of above files and if they are not there, to check if his server run some software that could automatically erase them, treating them as temporary , because of the extension tmp.
HP
HP 2009-07-14
Thanks for all your replies! I've solved this issue.
