How to write script to mutate and minimize amino acid (ex: ARG) with CHARMm force field ??
HI !
Because clean function is not amino acid force field .
Please give me a example !!
Thank you very much !!
消息编辑者为:tkc
Answers 1
HP
HP 2011-01-04
Couple of options if you are using Discovery Studio 3.0.  You can either run minimization of the mutated molecule interactively using the Minimization command on the tool panel.  Or you can use the Calculate Mutation Energy (Stability) protocol to generate the mutated structure.  The structure is optimized by CHARMm program and can be saved if you turn on save option in the advanced parameters.
If you are not using DS 3.0, it will take some work to get what you want.  A customized protocol is needed which will mutate a residue using Discovery Script and run CHARMm minimization using CHARMm Minimization component.
Lisa
