Suppose I have a set of superimposed structures (.pdb) as well as the structure based sequence alignment of those structure (.fasta). I am able to read both the structures as well as alignments in discovery studio. How can I link the structures with their sequences in the alignment Thanking you in advance..
They should be linked automatically after loading into DS. If they are not, then there must be some differences between the structure and the sequence, either in sequence name or sequence string. You can check if the sequence is the same as the structure by showing the sequences from the structures in the Molecule window and compare those sequences with the sequences from the alignment you got using other program.
Lisa
