How to calculate Percent Solvent Accesibility from Residue Solvent Accessibiblity?
I want to know that
How to calculate Percent Solvent Accessibility from Residue Solvent Accessibility?
It seems relative values about residue solvent accessibility per maximum solvent accessibility.
If true, I want to know maximum solvent accessibilities for all 20 residues...
Please, let me know more information about solvent accessibilities...
Answers 3
TY
TY 2008-04-15
The Solvent Accessibility calculation computes the Solvent Accessible Surface (SAS) of protein atoms and residues using a grid-based numerical algorithm with a solvent probe of specified radius.
The Residue Solvent Accessibility reported in the Data table, is the sum of the exposed surface area of all the atoms in that particular residue in that protein, in the units of Ã…2.
The Percent Solvent Accessibility reported is the Residue Solvent Accessibility divided by the residue solvent accessibility of the fully exposed residue calculated (internally) using an in situ tripeptide model, i.e. Gly-X-Gly model for a particular residue X in that protein.
HP
HP 2009-07-28
I tried to do something similar. I want to calculate the solvent accessible surface area of a ligand inside the intercalation site of a DNA. So, I tried to calculate the solvent accessible surface area of the ligand in open and closed form.
I expect to see the open form is smaller, as those surface area in contact with the protein residue should not count. However, I found both results are the same and I found a closed surface area around the ligand when I chose to use "open" surface area option. There are close residues (DNA base pairs) nearby. Why I cannot use see an open surface area?
HP
HP 2009-08-06
Currently, the open surface only count for atoms in the same chain. So, you have to merge the DNA chain with the ligand chain to see the effect of the open surface.
Another way to do it is to use the Solvent Accessibility command. You can calculate the solvent accessibility for the whole molecule (do not select anything and run the command) and then the ligand only (by selecting the ligand and run the command). After each calculation, in the Data Table, look for Residue Solvent Accessibility in Residue tab to get the value for the ligand. If the ligand has multiple residues, you have to sum up the values for all the residues to get the surface area for the ligand.
