How to calculate binding energy of antibody-antigen complex? I find that the calculate binding energy protocol could not work for antibody-antigen complex, so if I want to do this , how to do?
Thank you very much!
Another option is to use the attached custom protocol. It can be used for complexes of any type and even trajectories. Simply unzip the file and then from the Discovery Studio Protocols Explorer right-click over your User folder and choose Import and navigate to the unzipped .xml file. You might need to right-click over your User folder and choose Refresh but then you will see this new protocol. It was written some time ago but it still works with the current versions. I hope that helps.
Hello Fang. One option is to use the Calculate Interaction Energy protocol. This protocol calculates the interaction energy (van der Waals and electrostatic) between two sets of atoms. The input molecule should be typed first with CHARMm forcefield.
We can select the antigen chain to define a group as “Atom Selection 1”, and select the antibody chains to define a group as “Atom Selection 2”. Select ‘Implicit Distance-dependent Dielectric’ as the Dielectric Model. The calculated interaction (binding) energy between antigen and antibody will be reported.
OK, Thank you very much !
Thanks very much !
