After submitting a parallel CDocker calculation, I closed DS Visualizer. I later went back to check on calculation by reopening DS Visualizer and receive an error stating that a previous version is running that is not compatible with the current Pipeline pilot. This impossible since I just used the same setup to get the successfully start the calculation. When trying to rechoose the server, the test returns and error in the seventh line stating "version of DSCORE FAIL." When the calculation is complete, this error is no longer present. Can you please help? While my calculation is running a few days on 1000 compounds, I cannot visualize anything else!
Hi Ed. I'm looking at this in your Support case currently and investigating possible causes.
