Equation coefficients in the 3D QSAR model
Hi all
1. How do we determine the contribution of VDW and Electrostatic interactions in a 3D qsar model. I am looking for a quantative answer
2. Though we use a PLS model to remove well correlated descriptors, why does the equation representing the activity in a 3dqsar model contain many terms of VDW and ele. The number of components selected in PCA in the 3dqsar by default is only 3, so i shud expect only 3 components and not 120 components
3. can someone help me out to analyze the grid file. i can understand that there are edges of the grid and the angles of the grid are depicted in the first line. but the second line contains equation coefficients, how to interpret it. In which format is the grid file present: PDB, CHARMM or any other format
Answers 5
HP
HP 2013-10-17
1. In ModelDescription.html there is a coefficient-variable table.  It contains the coefficient of each contributing vdw and electrostatic interaction.  The same information is also in the grid files, but in less readable form.
2. Each component is a linear combination of all interaction terms.  One component or many, you will see the same number of terms.
3. The grid file format can be found in Discovery Studio help:  Using Discovery Studio > Working with files > Supported file formats > Insight II Grid (GRD)
HP
HP 2013-10-18
I think you are mixing up the term component here.  A component, a.k.a latent variable, is a linear combination of the original independent variables.  It is not possible to only use two or three of the original interaction terms to describle the PLS model.   The documentation about PLS model in DS 4.0 help can be found in: Small Molecules tools > Theory - Small Molecules > Partial least squares
The energy field is partitioned into 3D grids in 3D QSAR.  Each energy at a grid point is used as an independent variable in building the PLS model.  vdw_4_5_2 represents the VdW interaction at grid point (4, 5, 2).  The grid set up information (origin and grid spacing) in stored in the header of each grid file.
RR
RR 2013-10-18
Thank u very much dzhang. I was bit confused with the components and the latent variables. Thanks again for enlightening me.
But is it possible to know which of these independent variables were coded by the latent variable.
RR
RR 2013-10-18
Dear dzhang
Thanks for the timely response.
1. Though we use PLS method and our interest is to reduce the number of components [vdw and electrostatic], the coefficient table contains more than 100 variables. So an equation describing the activity will be a linear equation of the terms contained in the coefficient table. I would like to know as what is the use of PLS then. PLS basically should reduce the variables and by default in 3dqsar protocol, we had used only 3 components to be displayed.
2. What do the numbers in vdw_4_5_2 signify. I went thru the protocol from pipeline pilot for 3d qsar and tapped several intermediate outputs to understand the protocol. In one such event I also found that there are three variables that are changing continuously Ix, Iy,Iz. Do they refer to moments of inertia along three axis.
HP
HP 2013-10-18
The short answer is all of them, maybe except those removed due to high correlation.  If you want to know the coefficients of the independent variables in each component, then no. This information is not saved in the final model.
PLS is not the best method if you want to interpret something. Although you can try to cherry pick variables that are important, it is usually less efficient. There are other methods that can do better in interpreting data.
