Since we have installed the lastest version of DS, we meet some view problems : unclear display of the text and images, menu bar seems zoomed and it is not possible to unzoom, some menu bars appear duplicated, and the molecule window iappears as a black screen. Please could you help us finding solutions to these difficulties ? many thanks !
Hi Catherine, by any chance are you displaying on a 4K monitor? If so, did you try reducing the screen resolution to see if it helps? Also, if possible can you attach some screenshots of the behavior?
Hi Catherine. Are you displaying the Discovery Studio client on a Windows or Linux machine?
Hi Carol, my PhD student is displaying DS on a windows machine.
Thanks Catherine. Could I confirm that your student is working with the Discovery Studio 2021 client please? This version was updated to support higher resolution monitors on Windows. If this is the right version, could you add the details of the resolution being displayed please? Can I also check if they ran the Optimize Graphics Settings command (under the Help menu) and accepted the recommended settings please?
Dear Carol, I confirm that my student is working with the DS 2021 client. Note that we have the same screen resolution problems when using the DS 2021 visualizer (no problem with the older version). The result of the optimize graphics test give the following information: polygon antialiasing passed; cylinder shader failed; performance excellent; line thickness passed; all tests complete passed. The resolution being displayed is as follows: 1920X1080; fréquence de rafraichissement 60,049 Hz; profondeur de couleur 6-bits; format de couleur RVB; espace de couleurs plage dynamique standard SDR. The characteristics of the graphical card are Intel(R) UHD graphics family, Intel vidéo BIOS, 8120Mo. I hope we'll find a solution as soon as possible because we can't use DS due to these problems. Thank you for your help !
Here are some screenshots of the behaviour using DS2020 and DS2021. As you can see, the resolution with DS2021 is bad. You can also see a screenshot of the behaviour of DS2021 when using two screens.
Hi Catherine, thank you for the information. I’d like to get some more details about your display setup. Do you see this problem only when you use two monitors or sometimes you just use one monitor?
Please check your display settings in Windows. Right-click on the desktop and select ‘Display Settings’. You should see the representation of the available monitors at the top of the dialog box. Click on Monitor 1. Scroll down to Scale and layout and note what the setting is. Next go to Display resolution to see what is shown as the current resolution. When you click the dropdown arrow, what’s the highest resolution shown on the list? If you don’t see any resolution higher than 1920x1080 then it is not a high res monitor.
Before DS2021, Discovery Studio had issues displaying on high resolution (4K) monitors – menu or dialog display text may be cutoff or unreadable. These issues have been fixed in DS2021 on Windows.
Since you have described the opposite behavior – display in DS2020 is fine and the anomaly is with the DS2021 version, so I’m guessing you’re experiencing a different problem.
You ran the Optimize Graphics Settings test in DS2021 and see “Cylinder shader: Failed”. I’m curious, could you run the same test in DS2020 and see if the Cylinder shader test passed or failed?
If you haven’t tried in DS2021, go to Edit > Preferences > Molecule Window > Graphics, please try turning off ‘Hardware acceleration’, click Apply, then OK. Exit the DS2021 client and re-open it. Does this help? The Hardware acceleration may already be greyed out since you have the Intel integrated graphics.
Hi Catherine, another note here. There is a recent bug report concerning using DS2021 with two monitors: Context menus in DS2021 client may not display correctly on a secondary monitor.
For details please go to our Knowledge Base: https://support.3ds.com/knowledge-base/ enter in the Search bar there, BR10000308439 to view the detailed explanation.
If this bug sounds similar to the behavior you’re seeing, you could try the workaround described in the bug report. i.e. Setting the Font Scale to different values (e.g. 100% on one, 125% on the other) on the two monitors, then the DS2021 client can be used on both monitors and the menus will display correctly.
