I use Discovery Studio 3.0 Client under OpenSUSE 11.4 distribution with the libXpm library already installed. After docking calculations (CDOCKER, GOLD) started, the following error message is showed: "Failed to load ppchemapi library". And no results are displayed.
Thank you in advance for help.
Regards
Dariusz Sroczynski
It seems your installation probably did not run successfully. I would suggest you contact Accelrys Support and they can guide you to diagnose where went wrong.
It is likely that you are missing the 32 bit version of the libXpm system library on your computer.
Please try installing the 32 bit version of the libXpm library.
Thank you very much for advise, however, the 32-bit version of libXpm library is installed.
Best wishes
Dariusz Sroczynski
From our experience the error message “Failed to load ppchemapi library” is usually due to a missing system library on the Linux machine (probably libXpm).
You can try running the following commands on the machine:
cd/DiscoveryStudio31/lib
setenv LD_LIBRARY_PATH .
ldd libppchemapi.so
Check the ldd output to look for any libraries listed as “not found” (e.g. libXpm.so.4 => not found).
Install the missing libraries should resolve the problem. I hope this helps.
