Hi all
I am wanting to create a similar molecule as
https://en.wikipedia.org/wiki/Chemical_polarity
showing the red/blue surface corresponding with partial charge of the atoms.
I have a drawn an H2O molecule. From what I have learned from the help, I should go to Display - Style and then chose 'by grid'. However, this is greyed out. I tried to add several types of surfaces (Structure/surface), but I never can tick the 'by grid' option.
Could anyone help me with this ?
Regards
Diederik D'Hert
Hi Diederik. After you add the surface for the H2O molecule, you can select the Coloring option Color by “Interpolated Charge”. Toggle on ‘Legend’ in the dialog. You will see the surface colored by red-white-blue. Red indicates more electronegative and blue indicates more electropositive area. The corresponding legend of the charge scale will be displayed in the window. You can also apply the CHARMm forcefield typing to the molecule first and that will assign the atom partial charges, then you can color the surface by ‘Atom Charge’ or ‘Interpolated Charge’.
The “By grid” option for surface coloring is only available if you have run the ‘Calculate Electrostatic Potential’ protocol first for the protein molecule and the ESP grid will be created. Note that in order to run any protocol jobs you would need to have the DS client connected to a DS server (Pipeline Pilot server).
Hi Diederik, try using the Calculate Electrostatic Potential protocol under Run Simulations. The output will be a surface colored by Grid values of the electrostatic potential. Here is an example:
@TY Hi, unfortunately it doesn't. I get a legend going from red over white to blue, but the surface stays all-red.
This is what I did, step by step.
I have drawn the H2O
Structure > Surface > Add - I chose VDW - Color by "Interpolated charge"
The surface doesn't change in color.
@JS Thanks. But where do I find that protocol (sorry for the dumb question, but I am looking and looking ... )
Are you using the free DS Visualizer or the full licensed product? If you are using the free DS Visualizer you will not have access to any protocols.
Hi, just to clarify: when sketching small molecules, no partial charges are assigned automatically. Look in the Partial Charge column of the Atom tab in data table. You can use Chemistry > Charge > Calculate to get some atomic partial charges assigned using the Gasteiger method. Then surface coloring with either Atom Charge or Interpolated Charge should work.
