Defining feature weight
I'm using the 3D QSAR pharmacophore generation protocol. I'd like to define a particular feature (PI feature) to be an anchor for all ligands to be mapped. I thought that this could be done by manually adjusting the feature weight but I couldn't quite figure that out. Is there a way to specify that all compounds should map to at least this particular feature, both for model generation and Ligand Pcore Mapping?
Thank you!
Answers 6
HP
HP 2008-09-08
In DS 2.1, you can select a minimum and maximum value for each feature using the Features parameter in the pharmacophore generation protocols (3D QSAR Pharmacophore Generation and Common Feature Pharmacophore Generation). When selecting the PI feature, choose a value of 1 for the Min and value of 1 for the Max. This will ensure that every generated pharmacophore will have at least one PI feature.
You can use the Screen Library protocol to screen ligands using pharmacophores that must have the PI feature. To designate which features are required, use the Selected Features parameter found under the Input Pharmacophore parameter. The parameter help of Selected Features gives details on how to use the parameter.
TN
TN 2008-09-09
Thank you Jon. Actually I would like to ensure that in the model generation, all ligands will be required to map to this specific feature. Is this possible? In essence, I would like this feature to be the most important and to serve as an anchor for mapping.Is there a way to manually adjust the feature weights (as the 'True' setting for the variable weight parameter did not help.)
Thank you,
Tammy
HP
HP 2008-09-10
Hi Tammy,
Setting the variable weight parameter to true allows all the feature weights to vary. If increasing or decreasing a specific feature weight improves the correlation with activity, that pharmacophore will be kept during the optimization. However, it is not possible to change the relative weights by hand during the model generation.
It is possible to change the feature weights in the UI after the model is generated (select feature in Hierarchy View, right click, and edit Weight property). Of course, this will affect the fit scores and regression results of the pharmacophore and will likely make activity predictions inaccurate. You may be able to re-regress using the Regress Pharmacophore component after changing the weight by hand to get reasonable results again.
Regards,
Jon
TN
TN 2008-09-17
Hi again Jon,
So I've given up on biasing the model generation but for subsequent mappings... I really would like to specify a certain feature as being more important than the others. I tried manipulating the weight in the hierarchy view but it didn't really seem to have an effect.Although I wasn't really sure of the weight ranges or values to use (I tried several.) Is there a way to do a more manual type mapping? Using tethers or something?
Any advice would be greatly appreciated.
Thank you,
Tammy
TN
TN 2008-10-08
Is there any way to map compounds to a pharmacophore model other than the Ligand Pharmacophore Mapping protocol? Is there a way to influence the mapping, because I've found that some of the mapping results do not seem very reasonable. Any help/advice would be very much appreciated.
Thanks,
Tammy
HP
HP 2008-10-09
You can also use the Screen Library protocol to map ligands to a pharmacophore. One benefit of this protocol is that it allows you to designate which features are required to map using the Selected Features parameter found under the Input Pharmacophore parameter. The parameter help of Selected Features gives details on how to use the parameter.
