I'm trying to run a simple protocol from a perl script. If I run my scripts from within Discovery Studio, these scripts work fine. I'm having trouble when I try to to run these under linux using perl (i.e. from the command-line). The scripts fail to establish a connection to the pipeline pilot server.
Here's my script:
#!/usr/bin/env perl
use strict;
use DSCommands;
use VisProtocolCommands;
use Getopt::Std;
my %options=();
getopts("p:", \\%options);
my \\\$pdbfile = 0;
if (\\\$options{p}) {
\\\$pdbfile = \\\$options{p};
} else {
die "usage: -p pdbfile\\n";
my \\\$parameterMap = Protocol::ParameterMap::Create();
my \\\$server = "localhost:9943";
\\\$parameterMap->AddItem("Input Protein", \\\$pdbfile);
my \\\$runpath = LaunchProtocol("Protein Preparation", \\\$parameterMap, \\\$server);
print "\\\$pdbfile\\n";
Here's my output:
/opt/software/DiscoveryStudio40/bin/perl.sh proteinPrep.pl -p ~/mypdb.pdb
Connecting to server...
Warning: Failed to establish a connection with host localhost:9943. Please select another Pipeline Pilot Server to connect to.
at VisProtocolCommands.pm line 71 in static function call Create
No server connection.
mypdb.pdb
Are there any environment parameters that I need to set, such as the location of the license file? Here's the environment variables that I have set currently:
export ACCELRYS_LICENSE_USERNAME=\\\$USER
export ACCELRYS_LICENSE_PLATFORM="linux"
export AccelrysRoot=/opt/software/DiscoveryStudio40
export ACCELRYS_ROOT=\\\$AccelrysRoot
export LD_LIBRARY_PATH=\\\$AccelrysRoot/lib:\\\$LD_LIBRARY_PATH
export PERL5LIB=\\\$AccelrysRoot/lib/vendor_perl/5.8.9:\\\$AccelrysRoot/bin:\\\$AccelrysRoot/lib/5.8.9:\\\$PERL5LIB
export PERL5LIB=\\\$scriptsDir/DStudio:\\\$PERL5LIB
export PATH=\\\$AccelrysRoot/bin:\\\$PATH
Thanks.
Allowing anonymous login seemed to fix the problem for me. I can now connect as expected.
