Can not run DS Visualizer on Fedora Core 6
I have been able to install DS visualizer without any problem. However, when I try to open it, it gives the following errors:
1. Failed to load Mdm3dPlugin
2. Failed to load ReflectionDataPlugin
3. Failed to load plut-in StudyTablePlugin
4. Failed to load the module 'OtdPlugin': /usr/local/src/Accelrys/DSVisualizer17/lib/libaccordcore.so.6: cannot restore segment prot after reloc: Permission denied
I would appreciate if you can help me resolve this problem.
Thanks
Answers 2
HP
HP 2007-03-03
After doing a Google search, I was able to fix this problem by changing the security context using the following command.
chcon -t texrel_shlib_t /usr/local/src/Accelrys/DSVisualizer17/lib/libaccordcore.so.6
GM
GM 2007-03-04
Hi Kumar,
Many thanks for the information about FC6 and the workaround! Although we don't actually support FC6 right now, this solution is probably applicable on systems where SELinux is enabled (which is the default on FC6).
It looks like you installed DS Visualizer as root. Was this the case?
I'll log this as an issue, so we can investigate a little more as we develop the next version of Discovery Studio.
Regards
---Glen
