The purpose of this script is to analyze a series of Models generated by the BuildHomologyModels protocol in DS 1.7.
This script retrieves the PDFs per residue for each model and writes those to single file called Mod_Analysis_Results.msv (in the specified BuildHomologyModel job's directory). The atomic coordinates in this output .msv file are those from the first model.
INSTALLATION: Save modeler_analysis.pl to a local directory or location accessible from the Files Explorer
USAGE: From the DS Client: From the Files Explorer, double-click on the modeler_analysis.pl to launch the script or right-click on the file and select Open With | Script Window then launch the script using the Run command from the Scripting toolbar.
From a MS Windows command prompt: Type
modeler_analysis.pl
From a Linux command prompt: Type
modeler_analysis.pl
DISCLAIMER: This custom script is compatible with Discovery Studio 1.7, 2.0 and 2.1. It is provided "as is" and is NOT supported by Accelrys nor is it warranted for any purpose whatsoever. The user assumes responsibility for any malfunctions or bugs.
REQUIREMENTS: You must edit line # 24 and replace the value of $dir with the path of the Output directory from your particular BuildHomologyModels job.
EXPECTED RESULTS: When the script is run from the DS Client, you will see a new 3D window appear with the name Mod_Analysis_Results. In the AminoAcid tab of this windows Molecular Data Table you should see new attributes (columns) one for each model that was processed. These will contain the PDF N_Totals for each amino acid in each model.
In newer versions of DS, the Build Homology Models output is a single dsv file containing the model(s) and templates. Therefore, the script has been modified to work on that new output and assumes it has already been loaded into a Molecule Window. The new properties (PDF N_Total) are added to the Amino Acid rows of the first model. To chart the data be sure to make only the first molecule visible since it is the only molecule with the added properties.
