I have a pharmacophore model created with Common Feature Pharmacophore tool. On the other hand I have ligands used to create pharm. model docked to set of receptors (using external software). What I want to get is to map pharmacophore model on top ranked pairs ligand - receptor. Algoriht my script is following is:
Everything works fine until alignment step: ligands are not aligned properly, furthermore, tethers are not being reset at the end of alignment process (this may be the source of bad fits) and I couldn't fid the way to delete them on script level. Fitted ligands move separately from receptors they are grouped with.
My questions are
- is it possible to pin pair ligand - receptor together so they act like one molecule?
- is it possible to fit those pairs to pharmacophore model using DSScript?
Thank you in advance for any help
Stefan Mordalski
- Read pharmacophore model and ligands used to generate hypothesis
- Iterate thru ligands and for each read corresponding pair receptor-hit, for each step:
- Group newly read molecules (the idea behind it was to tie receptor with ligand so they move together)
- Select ligand from pharmacophore and docking output and make tethers
- Align molecules
- Deselect molecules and proceed to next ligand from pharmacophore model
- Save everything as .msv file
My questions are
Stefan Mordalski
