ADMET Descriptors
When I obtain  any ADMET data. Help part of DS2017 is not enough to evaluate the result. Could you give me detail information about ADMET Descriptors pls? How can I assess ADMET_CYP, hepatoxicity, ....etc? Do you have any acceptable range tables or data to be available for these obtained descriptors of any canditate drug?
Answers 2
TY
TY 2017-02-22
In DS Help, the Theory section provides detailed information for each ADMET Descriptor: the data set used for the development of model (including literature references), a table lists the performance evaluation of the model, and a table lists the computed properties.
See these details in the sections under the Contents tab in DS Help:
   Small Molecules tools > Theory - Small Molecules > Theory - ADMET Descriptors
Although we don’t have the acceptable range tables, there is a table for each model listing the performance data of that model from the validation studies.
For example, the table in the ADMET – Hepatotoxicity model section:
comment imagecomment image
WS
WS 2017-02-24
Dear Tuğba,
do you mean the acceptable ranges for the predicted values or the descriptors used in the model ?
The models for Cytochrome P450 2D6 inhibition, Hepatotoxicity and Plasma protein binding have an "_Applicability" field, which you really want to read "All properties and OPS components are within expected ranges", which means that your compound lies in the chemical space covered by the training set and is not too different.
The Absorption and BBB models check for this intrinsically using their 95% and 99% confidence ellipses.
Regarding the output from the models:
You probably want to avoid Cytochrome P450 2D6 inhibition and Hepatotoxicity for your compound, so the predictions should be FALSE.
For the other endpoints, the desired outcome will depend on your project.
Plasma protein binding decreases the effective concentration of free active compound, but also increases its lifetime. While typically you want this to be low, there many cases where levels above the threshold of 90% are acceptable, sometimes even desirable. See e.g. this blog post for pointers to further information. PPB is an important piece in the data puzzle, but always needs to be interpreted together with the other properties of your compound, most notably its activity and excretion.
The same is true for the other ADMET parameters:
Blood brain barrier penetration should be Medium or better, if your target is located in the CNS; if not, you will want it to be Low, to avoid possible side effects. Be aware that the model predicts the intrinsic potential to cross the BBB and does not cover effects like active uptake of efflux.
It depends on the balance of polarity and lipophilicity of your compound(s), as do Human intestinal absorption and Aqueous solubility, where "best" values will again depend on the location of your target:
too polar compounds will remain in the extracellular liquid or not be absorbed at all, while too lipophilic molecules may have problems achieving the free fraction necessary to be active.
So, unfortunately, there is no result that will be acceptable in all cases and the art of medicinal chemistry lies in finding the right balance between all the relevant properties.
Good luck in your efforts achieving this.
