Windows says I can't delete SW file... SW or Windows issue?
Sometimes I try to delete a SW part or assembly file. Thereare NO files open in SW at all. But, Windows will complain that itcannot delete because it is in use by a program. If I quit SW, thenI can delete the file.
It is not consistent enough of a problem for me to nail down ifthis inability to delete the file is just a transitory thing. Butit does last more than a minute or two.
Notes; Files are all on a network server. I normally crash 2 or 3times a say, and so leave behind all the ~ files.
Is it that SW is not telling Windows that it has released the file?Is it that Windows itself is just taking a long time to catch upwith the SW program's status?
SolidworksGeneral
Comments 6
SF
SF 2009-03-25
Hello Joe-
RE:"Sometimes I try to delete a SW part or assembly file. There areNO files open in SW at all. But, Windows will complain that itcannot delete because it is in use by a program.If I quit SW, then I can delete the file."
This is normal behavior for SolidWorks, it holds data in the localcache even though the file is not "Open", well you can't see itdisplayed, but the data is still in RAM until the SolidWorksapplication is closed, even then it takes 10-30 seconds to clearthe cache.
Annoying isn't it?
DD
DD 2009-03-25
SW doesn't release the files, even if it appears that nothingis open.
Unlocker can help youthrough this without having to close SW. Just make sure you don'tuse it when the file in question really is open as a reference in adocument you're working on.
DG
DG 2009-03-25
While in Solidworks, click File > Open and move out thatfolder or change location to a different folder and you can deletethe file.
SF
SF 2009-03-25
I agree Deepak,
No need to exit SW or special programs necessary.
The reason for the error is as simple as SW keeping the object on alist for Recently Opened Documents.
SF
SF 2010-03-25
Is there anyway to disable the "Recently Opened Documents" option, in leui of Solidworks clearing the cache when a part is closed?
That is a trade off I would take in a heartbeat.
GG
GG 2021-08-03
Wow! This is ancient issue that I am just now experiencing with SW2017.  There has to be a way to fix this issue without manually clearing the launcher.  I have to close out of SW to clear out the launcher so I can delete a drawing.  Btw, the launcher is needed for what?
