Wierd dynamic highlight only on assembly sections
Using v2020 with Nvidia P400 on Dell Precision 3430.  When I section an assembly, highlighting/selecting is OK until I move a component just slightly.  After that I get all these weird dynamic highlight lines when I go to select faces, etc. (see orange color lines).  Have to do a force-top-assy-rebuild all the time.  Anyone else experience this? Thanks.
SolidworksHardware And Graphics
Comments 5
JH
JH 2019-12-18
make sure the setting "Performance > Use software OpenGL" is turned off in system options. Also, I would recommend updating your graphics driver to the latest NVIDIA driver from the R430 Branch as this is what is currently certified. I have placed a link to this driver from NVIDIA below.
NVIDIA DRIVERS Quadro Desktop/Quadro Notebook Driver Release 430 WHQL
SB
SB 2019-12-18
Hi Josh;
Thanks for the advice. I am currently using that exact driver.  Use Software OpenGL is off (actually it's greyed out and off).
SP
SP 2020-07-17
Could you please let us what SOLIDWORKS service pack you've installed?
GS
GS 2020-07-17
Scott Burson wrote:
Hi Josh;
Not that it matters here, but it will always be grayed out if you have a SW file open.
JS
JS 2020-07-31
Scott-
With 2020 the Enhanced Graphics setting is on by Default. There are a lot of systems that are not set up or adequate to handle this setting and it can cause a variety of issues. Sketches not showing, highlighting incorrect entities, dimension not showing until placed in sketches, mate dialog not showing as expected, random crashes, and slowdowns in performance. This option is set under the Performance Setting in the SOLIDWORKS System Options. SOLIDWORKS must be restarted after this option is turned off.
