When to avoid using a dot (.)
I want to document a best practice policy regarding when toavoid using a dot in the names of:
Part files
Assembly files
Drawing files
File paths (directories)
Configurations
Features
or anything else related to SolidWorks that is assigned a name
For file names, I am referring to an additional dot preceding thefile extension (for example: part.name.sldprt)
I would appreciate your comments regarding when using a dot in aname may cause problems. If the problem occurs only when using aPDM system, please specify the relevant PDM software.
SolidworksGeneral
Comments 3
SF
SF 2009-05-21
Josh,
As a general rule, we do not use a period or dot in our namingconventions.
Our only exception is in some of our standard parts, where weincorpoate the pitch, sometimes length and even CCs of fluid, rightin the name of the configurations, therefore you'll see partnumbers like:
20097M1.6C4
0014813.5X12
0087524.0X40MID
I cannot speak of any PDM/PLM or MRP/ERP systems other thanSmarTeam & Oracle when I say, the the use of "dots" does notpresent us with any problem.
SF
SF 2009-05-21
Josh,
PDMWorks Workgroup doesn't seem to have any problem with a . in thename. ProductCenter truncated the name at the first . it came to.(There are many other reasons not to use ProductCenter.)
DS
DS 2009-05-21
PDF Distiller truncates the name @ the first . also althoughit's not a PDM/PLM
