Weldment Cutlist is incorrect (Help)
So I have designed a chassis for a trailer, but when i go to create a drawing the cutlist has merged different weldments together so my cutlist does not display properly. in the model you can see its merged/highlighted atleast 4 different types of material under the same weldment in the cutlist for some reason and i tried updating it which didnt change anything.
Comments 2
BW
BW 2021-03-26
If the cut list is not updated, then the cut list table will appear blank when inserted into a part drawing. True or false? True.
WalgreensListen
DG
DG 2021-03-26
Share your model and drawing to check. In case you can not share them publicly then PM me to send you my email id.
If you can not share on email as well then talk to your VAR team to get it fixed.
One thing you can try is delete the cut list and create it again.
