Weld Gap Parameter?
So is there a parameter for weldgaps.  Here is the situation: We put .03 weld gap into our weldments and trims as a matter of course.  The boss has this pipe cutting machine. We use it for big jobs but not for small ones. It is so slick.  Company is Bend-tech and you import to the program an STP file of your piping.  The only problem with this workflow is the unit puts in a weld gap TOO!
We have a project that is MANY MANY handrails.  Is there a "Weldgap" parameter I can change globally or "sigh" do I have to go in and change them ALLLLLL  INDIVIDUALLY?
SolidworksUser Interface
Comments 3
AM
AM 2021-04-08
Yah I have some of those.  Job security of that type often feels more like job insanity.
HC
HC 2021-04-08
Yeh this is a legacy part.  Cut list is 279 parts long.  Groan!  And one of FOUR!!  I'll have to consider if it is worthwhile for the future to make it a global variable.
Haa Haa Job security!
AM
AM 2021-04-08
The only answer I can provide you with is at this point is: depending on how you set up your part.
You could set it up as a global variable and create a link to it when you initially create the file so that is is simple to change later.  But if you have the part already built you will have to alter the weld gap at each feature.  Depending on how many features it is will determine how painful of a process it is.
