Tangency and size errors when exporting to DWG
I am running SW2007 and AutoCAD 2007. When I export a SW file toDWG, arcs lose tangency. Also, the geometry seems to be slightlyoff scale. For example, I had a cut extrude that was .0185 deep.After exporting, I dimensioned it in AutoCAD and it was .01850003.Anyone else seen or know how to fix this?
Thanks,
DanSolidworksImport export
Comments 4
SF
SF 2006-12-13
have you look the option for export to dwg ?
SF
SF 2006-12-13
Yes. I have 1:1 enabled.
Dan
SF
SF 2006-12-14
I convert a lot of .slddrw to .dwg. Never had a scaleproblem... even though SW warns me that one or more views is out ofscale every single time I convert.
Complex geometry often becomes messy. Variable fillets intersectingor fillets merging on a taper... translate non-tang. Or have shortlines that don't touch one side. Or create multiple 2d fillets thatare slightly different from each other even though it should be onefillet.
Usually it's stuff that can't be measured in 2d anyway.Occasionally though, the complex geometry creates a hard edge thatshould create clean 2d, but doesn't.
Translating to 2004-2006 format is much better than translating tor12 format. So check that.
SF
SF 2006-12-14
If you're using 2007, maybe consider exporting to acis,importing into AutoCAD and then using AutoCAD's flatten and sectioncommands to make your views.
