We tested systems last year and ended up with adequatesystems, but nothing spectacular, and some cuts were made to myrecommendations based on IT budgets...we don't need to get intothat discussion...Anyway, the graphics design management is finallywilling to pony up some cash for proper systems. We design verylarge assemblies (10K+ bodies), boilers & environmental systemsfor power plants. (See SWW2006 Design Contest Large Assy firstplace). Drawing performance is critical. These are our documents ofrecord, and deliverables to customers. COSMOS was a driver in thecurrent box choice, IT only wanted to support one platform, so wewent with dual-core. These upgrades will have no COSMOSrequirements, and minimum PhotoWorks use.
Our current systems are supposed to be x64 capable, I'm not 100%convinced, and still doing research on this. I really believe weneed to go to x64 to make improvements in performance. I will listcurrent specs below on the left and proposed changes/upgrades tothe right. In addition to hardware changes, we are moving to avaulted PDM system. I want these people working locally, they arecurrently shipping everything over the network to a compresseddrive...need I say more?
IBM Lenovo ThinkCentre M52 8113
Current Specs Proposed Upgrade
Pentium D 820 2.8GHz no change
WinXP Pro x32 Dual Boot for WinXP Pro x32/x64
SW2006 SP4.1 x32 SW2007 SP2.1
3.5GB Ram 8GB Ram (2GB x 4)
80GB, SATA-150, 7.2K rpm 80+GB, SATA-300, 10K rpm
Quadro FX 1400, 128MB FX 3500 or 4500, 256 or 512MB?
I found the RivaTuner and tried it, but could not get an option tomonitor video memory usage as explained. I think I understand thevideo memory vs. system ram addressing issue. Since we're notrunning PhotoWorks & such I don't think we need that much videoram. Am I wrong? Our drawings are as big as J88, 36" x 88".
Thanks for everyone's input to this forum!
SolidworksAdministration
Current Specs........................... Proposed Upgrade
Pentium D 820 2.8GHz............... no change
WinXP Pro x32.......................... Dual Boot for WinXP Prox32/x64
SW2006 SP4.1 x32.................... SW2006 SP5.1 x64 or SW2007SP2.1 x64
3.5GB Ram............................... 8GB Ram (2GB x 4)
80GB, SATA-150, 7.2K rpm........ 80+GB, SATA-300, 10K rpm
Quadro FX 1400, 128MB............. FX 3500 or 4500, 256 or 512MB?
Cheers,
Dan
Change the Pentium D to the Intel 2 Duo Core.
I think SW '07 is stable enough to make the move to it.
8GB...I'm jealous.
Go with the 512MB video card - remember, in the words of Tim Allen,"more power!"
Just my 1/2 cent.
Pete
You have been getting some input from the guys here. I will echowhat they have to say.
Pentium D's, Core 2 Duo and Xeon's are 64 bit capable. I would getrid of the Pentium D's, they are the old Intel architecture. Youwill want to look into the Intel Core 2 Duo's and Xeon 51xx seriesof processors. With what you describe as your assembly sizes Iwould be looking to get a C2D E6700 minimum or higher cpu. If youget a Xeon processor go with a Series 5150 minimum or higher cpu.AMD's are not on my list of preferred processors anymore until theycan come out with new CPU's to match the latest C2D releases fromIntel. The quad core solution (4x4) from AMD is way to exotic for abusiness workstation. Intel's quad cores look intriquing. At thistime SW can't take full advantage of it, but it may be aconsideration for future proofing your purchase. How long are yougoing to be keeping this machine?
Even though the Pentium D's have a higher clock speed they areslower then the new Intel C2D processors. Here is a link to Tom'shardware to give you an idea of what the C2D can do. The benchmarksaren't SolidWorks related but you will see that the C2D's are nowthe king of the hill. I would go with them over Pentium D's andalso the AMD cpu's. Look at the benchmarks that are more CPUrelated. Take a look at where your Pentium D's fall in the chart.You will be way down the list on most all the benchmarks.
http://www23.tomshardware.com/cpu.html
Here are links to a couple reviews of the Dell workstations. Thereviews will give you an idea of the hardware you will want to beconsidering.
http://www.deskeng.com/Article...rint-200612141532.html
http://www.deskeng.com/index.p...tent&task=view&id=1424
CPU's will give you speed. 64 bits give you memory allocation. TheCPU will give you the most speed improvements as SolidWorks is cpuintensive, If cost is an issue, I would keep your FX 1400 (nicevideo card) and go with the newer motherboard and best processoryou can afford. Also for cost savings, get a motherboard that iscapable of loading 8 gigs of memory, but only order 4 gigs ofmemory (4 one gig sticks). Take the money saved and put it into thecpu. You can easily add more memory or a better video card later.The CPU is the most important piece of the equation and the leasteasy to swap out.
The 80 gig, 10K SATA drives are an excellent choice. Those are theWestern Digital Raptors and they are the fastest non-scsi drive youcan get. We have been using them since they came out. Great drives.
The dual boot is a good way to go I think. This will keep you safewith regards to any legacy software or hardware that does not likethe 64 bit OS.
Also you need to make sure your designers aren't running a bunch ofother apps while they are using SolidWorks. I know it kills somepeople, but running iTunes or some other real-time streaming videoand sound apps takes away resources from SolidWorks. You want tokeep the machine resources allocated to running SolidWorks not allthe other stuff.
Regards,
I think I'll propose 2 options, one would be an upgrade to get usby for another year or so. The second would be a full-blown newmachine. In our corporate environment, we have to keep IT happyalong the way. I don't think they'd be willing to swap MBs, eventhough it might save some $$, and can be justified in man hourslost due to 'wait time'.
I agree 100% on not running extra apps, but some of these peoplejust don't get it. They run iTunes, weather stations, live web camsfrom downtown, and who knows what else? When I tell them itcontributes to poor performance and crashing, they look at me likeI'm an idiot, even when I show them on task manager. My efforts to'lock out' certain features have been frowned upon...I can't getfrustrated over it or I'll go nuts! I just shut it all off when Isit down and troubleshoot their system, asked them politely not touse it. I also tell them not to be so cheap, go buy a $10 CD playerat BigLots and forget iTunes at work!
Cheers all & have a great week!
HPxw4400 - customized
Intel C2D Xtreme 6800, X6800, 2.93 GHz, 4 MB, 1066 MHz FSB
NVIDIA Quadro FX1500 256MB PCIe
6GB (2x1GB+2x2GB) DDR2-667 ECC RAM 80GB WD Raptor SATA NCQ 10K 1stHDD
48X DVD-ROM/CD-RW 1st Combo Drive
16X DVD+/-RW DL LightScribe 2nd Drive
....$5,671....
The mobo only has 4 memory Slot$, but the extra ram will help,especially in x64 mode.
Thanks again for all your help, I hope to meet you guys (thatincludes Anna) at SWW.
Cheers!
(This is true with both the Dell 490 and 690 vs the 390. Bothsupport 8 DIMMs. With HP, I think you have to go with the xw8400 inorder to have 8 DIMM sockets. Should still be cheaper than thexw4400.)
Glad to see you back on the SolidWorks Forum.... :-) Your advice onsystems has been missed by me and I am sure many others on theforum.
Regards,
If the boss don't buy you that toy... call the union and goonstrike...
