SW2007 SP0 DVD Installation Error
I am trying to install SW2007 (Italian Version) from DVD andI getthis error :
Error 1335. The Cab "WinNT0.cab" is corrupted.
This maybe read error from CD-ROM , network o a trouble withthispacket.
Someone else has this problem ?SolidworksAdministration
Comments 8
SF
SF 2007-02-27
Stefano,
Non ho avuto quell'errore. Avete provato a ricaricare SolidWorks?Suona come la vostra installazione originale non ha funzionatocorrettamente.
SF
SF 2007-02-27
Ho rifatto l'installazione diverse volte ma mi dasemprequell'errore usando la versione DVD. Ho provato anche acopiarel'intero DVD sul HD ma l'errore rimane.
I have done installation more then 10 times, but always thesomeerror.
SF
SF 2007-02-27
State installando al vostro azionamento duro o ad una rete?Avete spento il vostro antivirus?
Are you installing to your hard drive or a network? Did you turnoff your antivirus?
SF
SF 2007-02-28
Now I have done installation with CD, and after more timeitworks.
Before with DVD I have tried to install with and withoutantivirus,and always on a single PC, but always the sameerror
SF
SF 2007-02-28
Eccellente! Sono felice che potevate ottenerlo installato.Forse il vostro DVD è corrotto. Comunicherei con vostroreseller e vedrei se potete ottenere un altro uno.
Excellent! I'm happy that you were able to get it installed.
Perhaps your DVD is corrupt. I would talk to your reseller and seeif you can get another one.
SF
SF 2007-02-28
Do you have the MSDS for that Italianglish?
SF
SF 2008-01-26
null
Stefano Tampieri wrote:
I am trying to install SW2007 (Italian Version) from DVD and Iget
this error
This maybe read error from CD-ROM , network o a trouble with this
packet.
RH
RH 2008-01-26
Regionalized DVD's like Solidworks require your DVD drive tobe set to the proper Region. Go to Device Manager, RMB on DVD Drivein question, Set to proper region, Reboot. Try your DVD install. Ifthis is not the problem, verify your DVD install works in anotherDVD Drive before assuming the DVD disk is bad. I recently had a DVDDrive that would read other DVD disk but not my Solidworks DVD.Replaced DVD Drive, Problem Solved.
