I find SW installation is giving me more problems with every new release.
Here is my story. I need multiple SW versions installed for software development. Until recently I had 2009 & 2010 on the same machine working fine in sw2009x64 and sw2010x64 subfolders in the default SW program files folder. I installed 2011 in sw2011x64, but I could not start it. Disabling HW acceleration and everything else did not help. RX shows nothing (except that my video card is not certified which I know). SW 2011 shows the splash screen and then quietly disappears. No messages, no info in the log files. Bad, but not as bad as it was going to get.
I downloaded 2011 SP2 and created admin image. Tried to install once - it failed with an MSI error message that I did not write down and is not in the created log files.
I decided to uninstall 2011 SP2 and try again. Did that. Then installed 2011 SP2.0 again. Guess what - it wiped my 2010 off my drive. As a bonus 2011 is still not working.
Warning #1 - if you try to uninstall a service pack it will uninstall your SW version completely!
Warning #2 - installing service pack as admin image will not prompt where it is going to install. At least mine doesn't.
Warning #3 - if you are installing 2011 SP and your 2011 is not there it will go for the next available version - it replaced my SW 2010.
What a pain. Every install/uninstall takes 30-40 minutes plus 1-2 hours downloading with zero control for where it is installing a service pack from admin image.
SolidworksAdministration
so just to say it in SW speak: I was trying to do 2011 update, but ended up upgrading my 2010 which in my opinion should never happen without being asked first.
Sorry to hear about the troubles you are running through. Do you have a network license or a sigle one?
Just installed 2011 x64 SP2 (OS Vista 64) and everything seems just fine. Design Tables seems to be ok too :-) Haven't tested PDMW yet.
We have FX570 in many workstations and that has been dropped from the 2011 supported list (with Vista). If we had XP or Win7 it would do. Anybody knows reason for this? Seems to work with Vista too but why not supported?
Edited: Notised that there are not any NVIDIA -card on the SW2011 supported list for Vista!
Thanks for the condolences! To answer your question it is a local license.
I finally got through it last night. after 4-5 hours of uninstalling and reinstalling. at the end had one more problem. SW2011 wouldn't start again. luckily this time it was producing a message from the "Activation Wizard":
"Contact your Administrator, can't write to the following log file: D:\downloads\cad\sw2011_x64\SolidWorks 2011 SP2.0\64bit\logs\hostname\myname_Actiavation.log"
The folder wasn't there from "64bit" on. I created the subfolders, tried - no, then created the file - still no. SW starts and hangs on the splash screen with the above message and a 20s countdown. I'm guessing that was my original problem with the attempts to install SP0 which was shutting down as well, but without the pop-up. Then I did some more reading and found that someone got around similar problem by running the "Activation Wizard" outside the installation. So you go to downloads, install the "wizard" and run "C:\Program Files\Common Files\SolidWorks Shared\2011\Activation Wizard\swactwiz.exe", activate 2011. Note that my 2010 was activated and 2011 beta also, but apparently for 2011 official release you have to activate before you can open SW. No more 30 days I guess!? Or maybe the beta messed things up.
If you have problems starting SW2011 after fresh install run "SolidWorks Activation Wizard" (can be downloaded from the SW portal).
This brings me to my rant about install folders for SW. Why does it have to put things all over the place? During installation it is trying to create/use folders and log files in my download folder? There are tmp folders for this type of needs. The Activation Wizard creates files in Common Files, Program Files and to top it off "C:\Windows\SolidWorks". I think SW installation has no business in the system folder. It is enough they sprinkle folders and files in Program Files and my root folder.
At the end I wasted at least 8 hours over 2 days trying to install 2011. And was asked a minimum of 6 times to fill out a survey about my experience.
