I am having trouble opening drawings sometimes. I can usuallyopen up a drawing when I first boot up Solidworks, but when I haveonly a couple drawing files and maybe a model file open, I go toopen another drawing file and it locks up. I can move around thedrawing, but the feature design tree stays blank and an I can't goto any other files I have open. I have to control-alt-delete outand start over. When I get back into Solidworks, it gives me anerror message that I don't understand. I am running 2 Gig of RAMand a pentium 4 processor. Does anyone have a solution?SolidworksDrawings And Detailing
I have had this happen w/2007 sp2. All I had to do was restart thecomputer.
Bill
I don't have a solution except to restart SolidWorks and lose yourwork.
Of course, you should discuss this problem with your VAR.
Give us some more specifics:
What service pack are you running right now.
Is it tanking on the same assembly or just the third documentopened
What video card are you using?
What's your process or and memory usage look like when the fileloads: are you pegged at 100% processor and all 2Gb
Where is this file-on the network or your local drive?
They don't call it SolidQuirks for nothing!
Ed Poole, C.S.W.P.
Engineer
The Cly-Del Mfg. Co.
SW 2007 SP 2.2
Dell Precision 690, 2MB RAM
ATI Fire GL V7200
It happens with our two notebook systems every now and then on sitewith a customer. Both the notebooks are running SW2007 SP2.2. Onenotebook is fitted with one gig and the other with two. It onlyhappens with drawings from this customer. The customer hasn't hadthese problems with the same drawings. The files are all on aWindows 2003 network server.
It mostly happens when we open and close a lot of drawings, and itlooks like when it has happened once it will happen more often.There are days when we don't have a single lockup and there aredays we have dozens..... Problems are not reproduceable. VARdoesn't have a clue also, the obvious trial and error; networkdrivers, video drivers etc.
Hopefully things have become better with SP3. At the end of theweek I will know more....
Good luck!
readthis
I have tried to remember to bring up the model 1st thenaccess thedrawing. This seems to resolve the issue.
Always check your CPU usage prior to closing downSolidworks...
If its at 100% Solidworks DID NOT CRASH!.. it issimpletaking its time because your RAM bandwidth isslow.... (especially if your running a Pent 4 setup)
I've seen A LOT of people say SW has crashed or locked up,when inreality, its just chugging away at data, and itwillrecover....
I am having the same trouble occasionally in SW 2007 sp 3.1,Itseems to happen to the files I had created in SW 2007 withpreviousservice packs when I was having so much trouble with SWcrashing alot. I have plenty of memory, 4gb. I have walkedoff while adrawing file was loading. For an hour and it will neverload. All Isee is the hourglass. So I have to force SW to shut downand bringit back up then the file will load in less than a minute.I wasunder the impression this was fixed in the last SP release.And yesBrent, mine always locks up while trying to load anAssembly. Thishappens to me at least 2 - 3 times a week. Hasanybody figured outwhy yet.
We are running on SP 3.0 here and have some pretty poor largedrawing performance issues. I did some testing and downloaded andinstalled SP 4.0 (early visibility). I noticed quite an improvementin performance. My VAR could only tell me its related to parasoliddata. If you look at the fixed SPR list, you will see some itemsthat reference drawing performance. I would recommend giving it atry.
Pete
In testing, I can open up parts and assemblies all day butopeningup the 3rd or 4th drawing does it every time. Any drawing,whetherthe referenced file is already open or not seems to makenodifference. I've rebooted, open and closedifferentdrawings. When I try to open the 3rd or 4th drawingit willhappen. CPU is idle. I can pan and zoom in thedrawing. The pull down menus (File,Edit,View,Tools,Window,etc..) allappear active but do not actually function.
This started happening immediately after installing 2007SP0. I've re-installed, and have the latest approved driversandno change. We're now up to SP2.1 and still the same.
I should also note that this problem does not happen whenrunningin 'software OpenGL', although everything slows down. Couldit be some other conflict that shows symptoms of videoissues? Both problem machines have FX3000 cards with therecommendeddriver.
I am subscribing to this thread in hope that someone with thesameissue has found a solution.
Thanks all.
Rich
Reading through the SPR's I saw no mention of anythingthatresembled my issue so I didn't bother for fear of'breaking'something else. I guess now I have a reason to trySP3.1. If this fixes it I will post back here.
BTW, for what it's worth, my issue does not seem toinvolveprinting at all since I could go a whole day withoutprinting andstill have the problem.
