Solidworks Flow -- Constantly Loses Faces on Defined Features
I've been fighting this problem for a while now & have finally reached the breaking point. In almost every flow simulation that I've run, I'll constantly run into issues where defined features "forget" the faces that I've assigned.
I can understand this happening if I'm changing model geometry that specifically pertains to said feature, but when it happens to a face/feature that I haven't touched (& pretty much happens all the way down the model tree), this can be aggrivating, especially when I have a 10+ hour run that finishes only to realize that certain critical faces have lost their definition (e.g. an outer shell losing it's radiative surface when running a solar loading analysis), which pretty much invalidates my entire run.
Occasionally I'll just save/close the part, open it back up & everything appears to have fixed itself. But as I mentioned earlier, sometimes this is missed before a run starts & then hours of simulation/solving time are wasted.
Is this a known bug and/or is there a seemingly simple fix?
Comments 2
RN
RN 2021-08-05
Hi Matthew,
To me that sounds strange and atypical.
I do sometimes notice that I need to manually "rebuild" Flow projects which you can do by right click from top of the project tree. This should reassociate anything without having to close and reopen the file, so it's a good thing to form a habit of just like frequently rebuilding the SOLIDWORKS model.
I also lately have been finding much better performance with the "Improved Geometry Handling" option.
Another thing that can cause the associations to get messed up is if you are using the options to reset the mesh settings and especially computational domain. This usually pops up the first time you run Flow but it is a sticky setting. If the domain is constantly being resized during modeling then that can cause faces to temporarily go outside the domain and goof things up. I set mine to "Never" so I won't have that happen by accident.
You can access the defaults for resetting mesh and domain, as well as the improved geom. handling, from the pull down menu Tools -> Flow Simulation -> Tools -> Options
comment imagecomment imagecomment imagecomment image
RN
RN 2021-08-05
Another note is, depending on severity of the model changes you are making, you may want to either unload the Flow add-in or disable the "Automatic rebuild" while you're doing the intermediary modeling steps.
Usually if I'm doing heavy geom. edits then I'll just unload Flow and load it back up again when I'm ready to make sure it isn't rebuilding the Flow project when it doesn't need to. I guess I have experienced what you're talking about to some degree, so this is the habit I've formed to avoid that.
