Should thermal expansion coefficient units convert??
I couldn't help but notice that the value for the thermalexpansion coefficient remains the same if you switch units. Ifyou're using inches I think you would want the units to be µin/in °F and if you're using metric units you would want
µ m/m °C.SolidworksGeneral
Comments 4
MA
MA 2008-09-30
In the end it doesn't matter since CTE is unitless.
DB
DB 2008-09-30
it isn't unitless... the length drops out, but thetemperature unit remains. The coefficient should definitely bedifferent going from imperial to metric. Example (fromwww.matweb.com) for high carbon steel the CTE is 9.90µm/m-°C or 5.50 µin/in-°F.
MA
MA 2008-09-30
Good point.
RS
RS 2008-09-30
The coefficient only changes if you change temperatureunits.
