I am fairly new to sheet metal. I am working on a project that has a jog, and I successfully created the default configuration with no problems, except that I discovered that I can't configure jogs to go in the opposite direction in a different configuration, so I had to completely change my strategy.
Strangely, when I decided to delete all of my previous work and start over, the exact same jogs I executed seconds before are giving me errors now, as an exclamation in a yellow triangle. Specifically:
"The radius/thickness ratio of this bend fell outside the current table. The default K factor will be applied instead."
There doesn't seem to be any way to make this error go away, and since I just repeated verbatim the same work I did before without an error message, I have no idea how to repair this. The error doesn't suggest any solution, either.
Any idea what I could have done wrong?
