Saving an Assembly as Vector Line Art
Our graphics department requires vector line art for packaging and instruction manuals.  This is an easy thing to do by saving the part as a DWG file and opening in Illustrator.  However assemblies will not save to a DWG file and to overcome this:
1.  Save assembly as an IGES file.
2.  Open IGES file in SW and save as a SW part.
3.  Open SW part file and save as an DWG file.  Note:  When the assembled part is open and before saving as a DWG, you may add perspective or camera view.  These view(s) are saved when the assembled part is saved as a DWG.
4.  Open DWG file in Illustrator and edit (remove) tangent lines as needed.
SolidworksAssemblies
Comments 7
SF
SF 2011-07-14
How about saving the assembly as a part file?
SF
SF 2011-07-14
I just tried crerating a .SLDDRW and doing a SAVE AS Adobe Illustrator (.AI) file.  This should give you exactly what you need.
SF
SF 2011-07-14
Agree, saving to a SLDDRW works but it does not give you the viewing flexibility for cropping certain areas or perspective views sometimes needed.
Saving the assembly as a part and skipping the IGES step sometimes does not work for me when I am pulling parts from different files, e.g., they are missing in the DWG file so, for large assemblies, I save as an IGES.  If I know all my parts are in one file I skip the IGES step.
JF
JF 2011-07-14
if you need to do this a lot you may want to consider additional software. 3DVia makes vecto art from the 3D file. on the plus side, it could be installed on THEIR computers, and then they don't need to bug you for the cconversion...
SF
SF 2011-07-14
Have you priced 3DVia?
SF
SF 2011-07-14
I do the manuals for our company and before we purchased 3dvia composer this is how I created our images:
Create a slddrw file of the view that you wish to capture and save the slddrw as a pdf.  Any editing that could not be done in SolidWorks, I then did in Adobe Illustrator.
3dvia is pricey, but worth it if documentation takes up a major portion of your product desing cycle.
JF
JF 2011-07-14
we did last year, and if I recall correctly, it was about equal to a seat of SW.
