Rotate part in assembly using mouse right click?
This problem has occurred after upgrading from SW2020 (SP.3) --> SW2021 (SP.3).
Previously when I right clicked a part and rotated it with the mouse I believe it rotated about the part origin or the point on the part where I clicked (which feels intuitively for me). This way the part was kind of locked in translation when I rotated it.
Now when I do this the part "flies away" as if the center of rotation is located very far away (I have checked, and the center of rotation is not the sub-assembly origin nor the top-assembly origin). In other words the part isn't locked from translation which makes it really hard to rotate a part in a satisfying way.
I get the same problem when using the "Rotate Component" command.
Has anyone else noticed this?
I haven't found a setting for changing this behavior, is there one?
Comments 2
PE
PE 2021-06-09
Does this happen with all parts?​
AP
AP 2022-09-29
I believe there was a basic feature in SW that did that years ago. I am having the same problem today.​
I think in Inventor I would click one time on the object where I wanted the center point of rotation to occur and then center click & drag or hold CTRL while doing the drag to rotate the part. Now in SW when I center click & drag it rotates the view point of the entire assembly.
I found that you can set up 'mouse gestures' to control commands. It sounds wimpy and emotionless to actually use the word 'gesture'. Someone admits to it, but if that is what is provided so be it. (It's like saying 'sibling' and not brother or sister) Programmers usually assume they are 'improving' existing functions, but rarely do hardened users really care.
Sometimes a set of mates can be too general or too strict and the part, assembly or sub assembly will rotate in a wild or erratic way. Similar to a single variable in a long equation changing the results dramatically.
