Re: Why can't I get rotary motion in the assembly when I get it in the motor sub-assembly?
Thanks for the help .
Yes I learned to make the sub-assembly flexible.
Now I have to recreate the rotary motion that I once had.
I will be back needing your help I'm sure
O.K. I'm back...
I'm trying to make this motor shaft turn inside the camming coupling and move it axially during rotation.  I made every sub-assembly flexible and cant get contact to work.
Would appreciate guidance.
Paul
Still no solution...?Maybe there is an "interference issue???edited by: Paul Toti
SolidworksAssemblies
Comments 9
DG
DG 2015-08-30
You never added all the files in the zip. Please make sure you do pack and go from the top level assy and then upload that zip here.
PT
PT 2015-08-30
I will get some help to do that. Thanks.
DG
DG 2015-08-30
With top level assy open, go to File > Pack and Go and in the pop up dialog box, select zip option.
PT
PT 2015-08-30
I hope that it is all in here.
DG
DG 2015-08-31
You can use the slot mate to keep the pin inside the slot. But if you need a real world motion then you need to use contacts in animation/motion manager.
PT
PT 2015-09-01
Thanks Deepak,
However I am confused.
I thought Animation only worked in SW Premium-I have 2015 Professional.  So as per your response I tried a slot mate and then Animation.  It worked and when I switched back to Basic Motion it also worked.
Sort of.
However, the coupling does not move axially.
As I recall, I previously had this working using only Contact and Rotary Motion in Basic Motion.  I could be mistaken. I will work with your solution and see if I can enhance it.
Paul
PT
PT 2015-09-01
Deepak,
Why does this Turning Thing work in Basic Motion and the Pool Roller does not?
DG
DG 2015-09-01
Did you tried setting up contacts in Pool Roller?
PT
PT 2015-09-11
Still no luck with contact and axial motion.
