proper speaker installing into ABS cover
hello all,
im designing a new medical device that has a very small speaker pointed to the back of the device.
im looking for some recommendations and/or a guide for properly installing the speaker so there will be no problems after.
im talking about things like: should there be a distance between the speaker and the rear cover? should i put a Poron between the speaker and the ABS rear cover? should there be a round rib around the speaker so there will be no sound waves reverberating into the device, and so on....
is there a guide for these kind of things? i looked in Google but only found guides on how to install speakers into your car door. which doesn't really help me.
by the way, its a very small 28mm diameter, 8 Ohm speaker.
any help in this area will be great.
thanks in advance,
Joel
SolidworksPlastics And Mold Design
Comments 2
SF
SF 2011-11-06
Joel,
You do need enough distance from the speaker to the cover to allow for the maximum movement of the diaphragm. If you are extremely lucky, you can get the excursion information from the speaker supplier. You can put a DC signal in and see how much excursion you get, but you are liable to burn out the speaker coil if you aren't careful. You can set up the speaker with a variable distance to the cover and check to see when it hits under a maximum loudness signal. Or you can just measure the deflection to bottom the speaker going the other direction and put the same clearance plus a bit for tolerances and variations.
Whether you want to put an enclosure over the rear of your speaker depends upon how much output you need, what frequency range you want to cover, how well sealed your box is, and a bunch of other factors. Speaker design is a complicated subject, as Anna suggested by pointing you at books about the subject. The cheap little speakers that you are probably using are pretty limited, so putting a tremendous effort into designing around them is not too smart. On the other hand, you can make up for some of their deficiencies by using good design techniques. If you have a sealed enclosure, the size of the enclosure will reinforce some frequencies and limit others. If you have the room, you can use a vented enclosure that might give you even more control, but the vent size tends to be bigger than the enclosure itself for small boxes.
Your local library, or a local university library will probably have a number of helpful books. I'm sure you can find a fair amount online as well, with the right search words. As Anna suggested, start with "speaker design" or "speaker enclosure design" or "vented speaker design" or "Thiele-Small parameters".
Jerry Steiger
