Problems With Static Analysis.
I am having problems when I model a static analysis upon adesignthat is made out of three different extruded parts (eachwithdifferent material properties).
The design itself consists of an outer ring (a rubber tire),aninner ring (the solid wheel) and plastic supports inbetween.
When I run the analysis on Cosmos, the deflection of the tiredoesnot take into account either of the center elements (i.e. thewheeland supports) and the rubber tire deforms right through bothofthem.
I have tried using "Contact gaps" but it has madenodifference.
I am using Solidworks 2006 SP4.1 and the latest SP ofCOSMOSWorks.
Thank you for any help.
FirstImage
SecondImage
P.S. The Solidworks file can be foundhere.
P.P.S. A picture of the "tweel" can be foundhere.SolidworksSimulation
Comments 2
SF
SF 2007-01-02
Hey, I recognize that tire! Great idea, I hope it becomesmainstream.
Anyway, it looks like your spokes (for lack of better word) andouter ring are not connected. Are they molded together in reality?If so, you are going to want to go back and remove the tiny gapthat exists between the spokes and outer ring. If they are supposedto be separate entities, then you probably want to try a ComponentContact for that outer tire (so you don't have to set theindividual supports). But the problem still remains that they arenot actually touching. I am not sure if it is in Component Contactor Contact Pair that you can set "Ignore small gaps" or somethinglike that to get around changing your supports, but i would makethe supports actually touch the tire.
SF
SF 2007-01-02
Thanks for the reply.
In the end I fixed the problem by remodeling that section ofthecomponent as a solid ring, and then using various cut-extrudestoget the shape that I wanted, as shownhere.
I used a bonded contact gap between the "tire" andspokes, andanother one between the spokes and hub.
