The following is an enhancement request that I submitted. Whoever reads this if you agree please go online and submitthis one. I am told there is power innumbers! I don'tknow about the rest of you butSolidWorks seems to make printingsuch a clumsy task. Why isthis so hard for SolidWorks todo?
Copy and paste the following into the SolidWorksenhancementrequest form for the printing category:
Add print settings in the system options that allow me to settheoptions based on print device. I envision a pull down forprintdevice and then options to set all the page setup informationlikepaper size, landscape, black and white, etc. Then savethisinformation in the user registry. I think this would workwellinside of your current scheme as this would just define thedefaultsystem options. The user would still have the ability toover ridethis upon printing the document. If you did this I thinkyou wouldhave a lot of very happy SolidWorks users.
One more for those of you that program against theSolidWorksAPI:
If you are printing via the eDrawing API it is extremely easytospecify paper size. Why can't they make it this easy fortheSolidWorks API?
How about them apples! I'mnotdisgruntled just frustrated.
SolidworksGeneral
SolidworksGeneral
I almost never have issues with printing. I set up my paper sizesfor my various printers, and off I go.
By the way, I make almost all of my mechanical drawings "B" size.Works great for distribution to almost any machine shop or sheetmetal shop. It is very easy for them to print and make duplicatecopies if needed. Larger sheet sizes are good for gift wrapping,but generally are a waste of resources.
BTW, the example size drawing "E" I gave earlier was only to provea point that there is nothing wrong with the way SW print iscurrently set up. The majority of production drawings I produce are"B" "A" "C" with a few "D" size (not related to SW butACAD).
I think its funny that 11-12 years later i am STILL on the web trying to find issues for printing. Supposedly there is an option (somewhere) that you can change on an HP printer so your lines print correctly (especially the dashed ones).
Every time i see a chat room or blog, saying "save it as a pdf"; i assume that person likes wasting time and are highly ineffective at their job. Save as PDF is a good way to TEST, it is not a solution.
If anyone knows of HP settings that need to change, please let me know. THANKS.
How does it print 'wrong'?
I haven't printed from SolidWorks in years... If I print I print from the saved PDF (we're 99% paperless). Quality is usually spot on better than from SW.
that would work in formal company. i work for small company where i do everything; and when others use cad they would remember to have to update pdfs evry time (which will not happen). I have dotted line in drawing, i print and it is solid line. seems to be linked to hp printers trying to optimize or something. ALL other centerlines, center marks print correctly. its only sketched lines that seems to give issues.
I get that yes there should be procedure, or pdfs or additional file management (which i also have to maintain and build out Workgroup software, and now find time time to build and learn sql for the new file management stuff (in my eyes unreasonable for mom-pop shop to do without great cost)....
so saving pdfs via macro is just 1 more thing i have to do/maintain, which would not be PDM managed.
want to know if there is a setting for HP printer that i can turn off (fyi. saving as pdf works fine) but i want to print direct.
There are 2 drivers: PCL and PS. See if one is better than the other.
Download all versions. Sometime PCL 5 works better then PCL 6.
Printer has firmware update also.
Check amount of RAM in the printer. I had funny results/problem disappeared after RAM increase.
I didn't know there was a huge problem with printing.
Like anything else, learn how to use it…then use it.
huge issue, seems i've been fighting on and off with differnt printers and versions of sw since 2000.
I select the printer, print to fit, 8.5x11 or 11x17. Never had any issues since 1995.
I never print to scale because every make of printer is different and are not exact. Ans I rarely fond that tries to measure from a printed drawing anymore.
So, what problems exactly are you having?
I, personally, use the 'presets' from the specific printer that I'm working with. Works well for me. Takes a little bit of time to set things up the way you want but you'll only do it once. [And again when the printer is changed! lol...lol] Others in the company where I'm working...not so much. lol...lol. I even get to have my name printed on each drawing. While others may shun having that information on documents, I relish that option! You have a problem…you know EXACTLY who to go to.
Just my opinion…
