There is a little known trick in PDM Workgroup for linking to an external file, such as a datasheet or PDF archive.
Here's how ...
*) Open a SolidWorks session, and 'pin' the task pane (be sure and set it to the PDM area to see vault)
*) Browse to your file using Windows Explorer
*) Right-click the file and select 'Create Short Cut'
*) Drag the shortcut to the SolidWorks task pane and drop it in the desired vault location
*) Delete shortcut from Windows Explorer
Now you can 'check out' the link and it it will immidiately open that file (from outside of the vault of course).
I like to drop it on top of related files so that they become 'attached' to them. I also like to keep the 'Shortcut' name, although you dont' have to.
SolidworksWorkgroup Pdm
Mike,
I do this all the time in linking external files to files inside of the vault.
Assuming you are talking about files that are not Solidworks files.
But what I do is easier then what you explained. All I do is find the file
in Solidworks explorer and click the check in button. Then when the
check in screen comes up there is a selection to link to a file in the vault.
Clicking that and finding the file shows the 2 linked in the vault.
That sounds interesting. Are you on Enterprise or Workgroup?
I am using WorkGroup, so we may be talking about two separate tasks?
What I am proposing actually appends a .LNK extension to the file name.
So, for example, in the vault you would have a file similar to this...
MyFile.PDF - Shortcut.LNK
In other words, the file does not really exist in the vault. Make sense?
It's more of a convenience thing for SolidWorks users in situations where released files are available for everyone to view, rather than stored in the vault.
So, instead of hunting around or using a third party app for finding files, you can 'link' to them.
