PDM Task to rebuild drawing
Hello Everyone, I'm hoping someone can please help me out. The below macro is really close to working. I am trying to create a PDM task where I can right-click on a drawing and it will run a task to open the drawing, check it out, rebuild/save, then check it back in. This macro appears to check out the file and check it back in with "Checked in by Macro" in the comments and the version is incremented, however it doesn't appear to open the file or rebuild or save it. Any help would be greatly appreciated. Thanks everyone.
Option Explicit
Dim pdmVault As Object
Dim strFullPath As String
Dim strFolderPath As String
Dim strFileType As String
Dim intFileType As Integer
Dim i As Integer
Dim strFileName As String
Sub Main()
    'Initialize macro
    strFullPath = ""
    strFolderPath = ""
    'Limit the macro to SLDDRW files
    strFileType = LCase(Right(strFullPath, 6))
    Select Case strFileType
        Case "slddrw"
            intFileType = 3
        Case Else
            End
    End Select
    'Grabs filename only
    i = InStrRev(strFullPath, "\\")
    strFileName = Right(strFullPath, Len(strFullPath) - i)
    'Create vault object
    Set pdmVault = CreateObject("ConisioLib.EdmVault")
    pdmVault.loginauto "[vaultName]", 0
    Dim folder As Object
    Set folder = pdmVault.GetFolderFromPath(strFolderPath)
    Dim file As Object
    Set file = pdmVault.GetFileFromPath(strFullPath, folder)
    'Check out if needed
    If False = file.IsLocked Then
        file.LockFile folder.ID, 0
    End If
    'open model
    Set swModel = swApp.OpenDoc(strFullPath, intFileType)
    swModel.ForceRebuild3 False
    swModel.Save
    swApp.CloseDoc strFileName
   'Check in
    If True = file.IsLocked Then
        file.UnlockFile 0, "Checked in by Macro"
    End If
End Sub
SolidworksApi/macros
