So I've been working on this for the last 2 days and can't seem to find the information anywhere. All the Macros I have found online seem to pull the "Revision" from the Custom Properties of the part. My macro needs to pull the "Revision" from the Configuration Specific Custom Property. I can't seem to figure out how to get this to work. Please help!
Dim swDraw As SldWorks.DrawingDoc
Dim swCustProp As CustomPropertyManager
Dim valOut As String
Dim resolvedValOut As String
Dim Filepath As String
Dim FileName As String
Dim ConfigName As String
Sub main()
Set swDraw = swApp.ActiveDoc
' Check to see if a drawing is loaded.
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
' If no model currently loaded, then exit
Exit Sub
End If
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
ConfigName = swView.ReferencedConfiguration
Set swCustProp = swModel.Extension.CustomPropertyManager(Revision)
swCustProp.Get2 "Revision", valOut, resolvedValOut 'Change the custom property name here
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\\"))
FileName = Left(swDraw.GetTitle, Len(swDraw.GetTitle) - 9)
swDraw.SaveAs (Filepath + FileName + "_" + resolvedValOut + ".PDF") 'Change the custom property text here
MsgBox "Drawing:" & Chr(13) & FileName & ".SLDDRW" & Chr(13) & Chr(13) & "With Revision:" & Chr(13) & resolvedValOut & Chr(13) & Chr(13) & "To location:" & Chr(13) & Filepath
End Sub
SolidworksApi/macros
Thank you so much.
Replace
with
Set swCustProp = swModel.Extension.CustomPropertyManager(ConfigName)
