Hi everyone,
I want to make a button with an over molded rubber (butyl or santoprene I'm thinking) ring. It's going to act like a ring on a speaker, with button section essentially being like a speaker cone. My plan was to mold the ring, then insert that in to a mold and mold the plastic button over it. Here's a pic of what I'm thinking. The dark grey is the main body this will all get over molded into. The blue would be the ring, and then the light grey would be the button. Will a setup like this work? Are there other parts out done like this? He's thinking that the rubber ring wouldn't be able to survive the plastic being molded over it. My reasoning for molding the ring first, then inserting it in to the button mold is to alleviate the undercut on the button where the ring sits. If you've seen it before, any chance you can send me a link to where it's been done like this in the past? Right now we've only spent about 1/2 a day on the design, so it's still really rough.
Thanks in advance,
Rich
SolidworksPlastics And Mold Design
Rich,
No picture attached.
Chris
Rich,
You didn't mentioned the material for the main part.
You have to find proper materials (certain material combinations are not advisable for 2 shots)
The general rule for 2 shot or overmold part is to mold the material with high temp. first and then overmold/second shot
Are you thinking of making a simultanious 2 shot mold?
hmmm the pic was showing for me. Does this work?
The main part will most likely be an ABS/PC. Currently we're using a Cycloy C2800.
Another thing to keep in mind is the rubber is softer and will not hold form or size when they pack the mold.
It takes injection presure to make a part dense without sink marks and hold size.
Rich,
I just wanted to reinforce the advice from John and Kevin. Overmolding is hard enough without pushing the limits of what has been done successfully in the past. I would mold the soft part in a U-shape around thin walls on the case and the button, reversing the way you did it, to get rid of the undercuts. You will need a larger thin section in the soft part to get reasonable button travel.
Jerry S.
