Why is it that on a reference plane that I created, whenever I select the "normal to" option on the plane, the model always shows up perpendicular with reference to the original plane (front/right/top planes) which was used to create the reference plane?
Is there any way to change this orientation of the new reference plane? I've been looking for a solution quite some time now but to no avail. This limitation always makes modification of the detailing even more difficult, while doing it by rotating the view/orientation of the model by updating standard views.
I can't quite tell from your question, but check this post out, as it may help you get planes oriented the way you're looking for. I'll warn you that it is a bit tedious.Wow, you actually can control the horz/vert orientation of a plane
If you are just doing drawing views, consider using the tools like “Align Drawing View > Horizontal” or inserting a "Relative to Model View".
