newbie assembly issue
HI, I hope you can help out there! does anybody know how tore-align an assembly to the correct orientation regarding theorigin? what I mean is, on rendering my assembly, the whole thingis 180 degrees rotated and upside down! when it comes to shadowsetc. it looks like the assembly is hanging from the ceiling! anysuggestions?SolidworksAssemblies
Comments 4
JM
JM 2009-04-30
One way is to reorientate it. Using your standard views, moveit to what you consider the 'Top' view. Hit your space bar, singleclick on 'Top', then click on 'Update Standard Views'. Check to seeif it's orientated correctly. If it's still backwards, click tochange it to back, space bar, single click on 'Front', 'UpdateStandard Views'.
If your shadows are still messed up, Turn off 'Shadows in ShadedMode' then turn them on again.
CB
CB 2009-05-04
Float all parts in the assembly after they are mated togetherand mate the entire assembly to the Top, Right, and Front planes.Once in the correct position fix the first part and delete mates toplanes.
JA
JA 2009-05-04
In a perfect world of perfect modelling, sure. But a coupleof unnoticed referenced bits of geometry can really cause yourmodel to disintegrate, then of course the undo button will begrayed out because you really need it...
SF
SF 2009-05-04
Adrian,
The simple answer is to turn off the shadow, orient the model theway you want, then turn on shadows again.
If that doesn't work, turn off the shadow, reorient the model theway you want, then turn on shadows and orient the model again.
Of course, if your assembly model is not oriented to your liking tobegin with, then you may have to follow Jeff's or Cody'ssuggestion.
