Need to drive Body-Move/Copy w/ equation - how?
I have created a surface feature by rotating the parent bysome angle. That angle pops up in the design tree area when I EditFeature, but I can find no other way to access it.
I need to drive this angle with an equation. How do I access thisvalue to stuff a new number into it?
I Auto-created a design table in hopes that it would show up there,but no luck.
[edit] - I'll add that the feature in question was created withInsert/Surface/Move-Copy/Rotate[/edit]SolidworksParts And Features
Comments 6
SF
SF 2007-01-30
Right click on "Annotations" in the feature manager and makesure "display annotations" and "show feature dimensions" areselected. Now all of your dimensions should be displayed for everyfeature. You can hide dimensions of a feature by right-clicking onthe feature in the feature manager or you can try to find thedimension you are looking for. Double click on the dimension youwant to edit and add an equation the way you normally would.
SF
SF 2007-01-30
BTDT - nothing shows up related to the feature in question.
I have attached a file SW2006. The last two features are the ones Iwant to drive with an equation. There is a 3 degree angleassociated with those features. That's the dimension I don't knowhow to reference.
GD
GD 2007-01-31
Karl -
Sadly, you cannot externally reference the angle dimension in theBody-Move/Copy property manager. I tried it in both SW06 and SW07.This would be a good topic for an enhancement request.
I didn't try it, but you might be able to mate the body to effectthe desired rotation and then reference that angle mate thru thedesign table or an equation.
SF
SF 2007-01-31
body operations can't be directly parameterized inSolidworks. What you can, however, do is add a coincident orparallel constraint between a body and a plane and then drive theplane with an equation.
SF
SF 2007-01-31
SF
SF 2007-01-31
John Burrill wrote:
What you can, however, do is add a coincident or parallelconstraint between a body and a plane and then drive the plane withan equation.
OK - figured out what you meant here. Got the job done. Thankyou.
